5 members (Gray_Ghost, frogfarmer, Otto Skorzeny, jay d, 50Chevy3100), 52 guests, and 3 robots.
Topics128,056
Posts1,055,804
#36849 06/28/2004 2:07 AM
Hi. I have a 54 Chev pickup. The guy who sold it to me said the original 235 engine had been replaced with an early 60s 261. I checked the block casting numbers on the 'net - its a 58-62 block all right, but a 235, not a 261. Removing the rad hose, I noticed that someone removed the thermostat! So I took the housing down to the parts store and the guy showed me the "correct" thermostat for the vehicle. That one was way too small; there is a lip inside the housing that it can fit against, but no way to hold it against the lip - it would just rattle aroung inside the housing. In an earlier post someone mentioned a "sink strainer" type thermostat. Is that what I need? If so, do you have the part number I need to give the parts guy? Thanks for your help.
Gord
1954 1/2 ton 235 4 speed
#36850 06/28/2004 6:26 AM
I added some pictures to show what I mean:
[img]http://members.shaw.ca/ghillsden/Images/neck.JPG[/img]
[img]http://members.shaw.ca/ghillsden/Images/therm.JPG[/img]
Thanks.
Gord
#36851 06/28/2004 1:02 PM
Junior Member
Junior Member
Looks exactly like the thermostat housing on my 261. Go to your parts store and ask for a thermostat for a 261 Viking engine. They were in the heavier duty trucks such as a school bus. Mine came out of a 1960 Chevy School bus Vivking 60. They fit right on a 235. Good luck
Roy Don
#36852 06/28/2004 10:14 PM
If my memory serves me, I believe the one for my 261 (a 160 degree thermostat) was for a '67 Mercedes. Exact fit. Works like a champ.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#36853 06/30/2004 5:25 AM
Thank, guys. That gives me a couple of options to try. Back to the parts store ...
Gord
#36854 07/01/2004 2:26 AM
I also have the same thermostat housing. My Local Auto Parts store sold me a Stant #13928. It doesn't look like the old "sink strainer" type I had, but it does fit OK.
I'd be interested to know what you might have come up with.
Steve
#36855 07/03/2004 4:15 AM
Thanks, 53 Therapy. The Stant number you gave me works! Stant also makes a 160 degree version of this themostat. (The last number is a 6 instead of an 8) I will have to make my own gasket though - the parts guy suggested RTV should work, but I have some gasket material on the shelf, so I think I will make one.
Gord
#36856 07/03/2004 4:19 PM
Don't forget to drill a 3/16" hole to vent air from the head. This can be a major cause of head failure on startup after refill. New 'stats are almost airtight and the hole is vital to saving the old mill. wink
#36857 07/03/2004 11:45 PM
Thanks, I will drill that hole!
Gord
#36858 07/07/2004 4:37 AM
Pardon my curiousity.... but where do you drill the hole...???
I have the same thermostat issue.... what they came up with is too small for my truck......but I have the old big one to compare.... so it's back to the store....
So the hole... is it drilled in the skirt of the new large thermostat..... because the newer ones are tighter sealing when cold...???
Thanks for your help and advice.
Bob C. :confused:
Bob C.
CMP Heaven
The Hammond Barn
#36859 07/07/2004 6:27 AM
Yes, drill it in the flange. Search the forum with "drill" and "thermostat" and you will find a lot of discussion about this. I had heard about this because before I posted my question I had made a similar search...
Gord
#36860 07/08/2004 5:17 AM
Thanks fellas
Did a search and found out all about he wee litle hole.... will drill mine this week end.
I found that large parts stores have stats in blister packs and damned the part number yoiu can match to size and temp if you bring the stats housing with you....even found a gasket... then I found out the Felcro gasket kit had a stats gasket anyways.
Appreciate your help.
Bob C. wink
Bob C.
CMP Heaven
The Hammond Barn
#36861 07/08/2004 10:00 PM
The 261 bypass thermostat does not require a bleed hole.
Paint & Body Shop moderator
#36862 07/11/2004 8:08 PM
Forgive my ignorance, but could someone please explain what exactly a "bypass" thermostat is?...and why you don't need to drill the hole? Is it any better than a regular thermostat?
Steve
#36863 07/16/2004 2:22 AM
Well I found some thermostat for both the 235 and 261 sizes..... None of the parts store lisitng was any good...so I did it the hardway.
Went to a large Canadian Tire store.... tye stock and display all sizes and style..... I ofund a brand name..."MotoRad".... readily available in the USA... they have a web site......
Now these are regular stats without the fail safe design that some of us would rather not have...
..the smaller one is a model 200 series supposedly fits a number of GM applications It is a dead ringer for the 235 smaller 2 inch mounting...and gaskets were available... total cost gasket and stat..$ 6.25 CDN
On my 261 I will be using the bigger stat a series 268.....both are rated at 180 and 160 and 195 degrees are also available. The bigger one is 2 1/2 inch across.... and has the little bleeder hole with a loose rivet....No gasket suitable with the slightly offset bolt pattern of the 261... no big deal to make your own. BUT the price of the larger size was $23.95 CDN.... according to MotoRad it offers a %60 percent increased flow area.
Hope the information is usefull to others and that my truck will keep a cool head.
Bob C. wink
Bob C.
CMP Heaven
The Hammond Barn
