1 members (59 fleet), 62 guests, and 9 robots.
Topics128,021
Posts1,055,353
Members48,420
#36820 02/24/2002 12:05 AM
ok...
I'm trying to pull the engine here, but I've got a question. the only bolts between the engine and bellhousing that I could find are 2 on top.
am I missing any bolts, and if so how do I get to them? or would it be easier to pull the 4 bolts between the bellhousing and tranny?
May the force be with you - SoloWookie
solowookie.com
#36821 02/24/2002 1:42 AM
There's a few more bolts between the flywheel and the engine.You will have to drop the flywheel to get to them. It will would be easier to take the 4 bolts out between the bellhousing and the tranny
You only get one shot at life.
Better have a good aim!
Later Dudes
Joe
#36822 02/24/2002 2:08 AM
yea thats kinda what I was thinkin... I got everything else ready to pull the engine (not that theres much on a 216 vs. my TBI 350's). I'll probably pull the engine either tomorrow or monday.
solowookie.com
#36823 02/24/2002 2:42 AM
Keep us posted on developments, we are all very anxious about the operation.... grin
#36824 02/24/2002 4:20 AM
Remove the u-joint on back of trans under the ball on tube and maybe the shifter if 4spd and pull out with engine. Just need to pull the two bolts in x-over holding in the bellhouse and the front mount on engine. OR, lift out trans first and then the engine and b/house. I use an eyebolt with washers on end with a cut-out to pass over one of the lugs on shifter ball area of trans. I just pass it down into the opening after removing the shifter, turn it to have washers lift up on the two pins in the tower and use picker to lift it and back away from engine, then lower to floor or roller rack to slide out from under truck. We used to lift the trans' at plant with same type tool all day.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#36825 02/24/2002 4:44 AM
actually I've thought about pulling the trans with the engine, but never looked at the truck enough to see what was involved. I have a leveler for my cherry picker so I very well may do that.
actually considered it already, but gave up on it when I saw the front of the trans had a cross member there so I wouldn't have to support it. I'll have to get the gear shift off, and then look the situation over again.
solowookie.com
