1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
could someone tell me the thickness of their water pump relocation plate thanks philip
from the pictures they look like 1/8 but i would like to be sure
i plan to make my own i run a machine shop and im not paying for
a piece of steel with holes drilled in it. so if someone could measure one id be greatfull
Measure the backing plate on the 216 pump you plan on mounting and duplicate that. If you don't have a 3/4" x 82 deg countersink on hand that will cost you as much as the whole adapter plate.
You Tube
cool will do, i have a full machine shop
that was easy took about an hour to design and cut the plate.
1/8 stock will work for anyone wanting to try one
