| | | Forums66 Topics128,210 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36815 05/23/2003 3:41 AM | Joined: Mar 2003 Posts: 10 Member | | Member Joined: Mar 2003 Posts: 10 | My 51 GMC 1 ton has a bad 228 in it now. I have the opportunity to buy a rebuilt 302 at a very reasonable price. Is there any reason I shouldn't install a 302? | | |
#36816 05/23/2003 4:31 AM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | HAVE A '56 W/ A 302 WHICH I'M STILL LEARNING ABOUT. SORRY I CAN'T HELP.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
#36817 05/23/2003 7:09 AM | | Anonymous Unregistered | | Anonymous Unregistered | Sidehill - the biggest drawback will be more power and probably better acceleration, higher top speed, rear tires will likely wear more and you will not get as good of gas mileage because you will be putting your foot into it more often . . . that and you will wear out your clutch and brakes faster than with the 228, be able to haul bigger loads and generally have too good of time with your old truck. I would not advise the swap. Perhaps you would be best served by avoiding the temptation to put that motor in your truck by sending me the name of the guy with the motor so that I can hold you accountable from time to time. . .  | | |
