| | | Forums66 Topics128,069 Posts1,055,890 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | could someone tell me the thickness of their water pump relocation plate thanks philip | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | from the pictures they look like 1/8 but i would like to be sure i plan to make my own i run a machine shop and im not paying for a piece of steel with holes drilled in it. so if someone could measure one id be greatfull | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Measure the backing plate on the 216 pump you plan on mounting and duplicate that. If you don't have a 3/4" x 82 deg countersink on hand that will cost you as much as the whole adapter plate.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | cool will do, i have a full machine shop | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | that was easy took about an hour to design and cut the plate. 1/8 stock will work for anyone wanting to try one | | |
