Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (NJC, 1955 1 Series, Wayne67vert, 1 invisible), 141 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#36742 04/07/2005 8:30 PM
As most of you know, I had my 250 rebuilt and with the help of many of you got it going.
I broke the engine in under load and my manual said to drive it 500 miles, then change the oil.
So the good news is, it made it to 500 miles, runs smooth no problems at all.
Bad news (I think); when I was pouring out the oil from the filter I noticed that the oil had gold particles in it. It had enough to look like gold metallic paint mixed with my oil. I didn't know if I struck the motherlode or if something is wrong with my engine. Runs great with no problems.
Is this normal?, my neighbor said it could be the break-in lube, but I don't think so. The particles are very very very fine and no other metal parts were in the oil. Oil was a dark amber, not black. Is the engine junk?
Any help would be appreciated.
Dano
69 C10 LWB 250 L-6/3spd
79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#36743 04/07/2005 8:41 PM
Do you know what kind of assembly lube was used to put it together? Some of those products have metallic-looking components, like the Never-Seez I use for lubricating head bolts, main bearing bolts, etc. If it's not making any expensive noises and the oil pressure is good, don't sweat it!
#36744 04/07/2005 8:52 PM
Thanx HRL
I have no idea what the guy used for lube.
Everything is AOK, Temp, Oil pressure, vacuum, etc.
No grinding, knocking, scraping etc.
The only noise is that of a smooth running L-6. smile
I'll stop sweating it, and start to enjoy it. grin
