3 members (Bill Hanlon, Erniegp, festerhairball), 86 guests, and 2 robots.
Topics128,054
Posts1,055,781
#36673 01/18/2002 11:09 AM
what ways can I improve performance of a 1966 292 without sacrificing mileage? After market intake? 2 barrel, 4 barrel, or tri power? Headers? smile Any suggestions are appreciated.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
#36674 01/18/2002 1:26 PM
Headders, better cam and better carb. And if the engine is in good shape, increase compression a little. Mill the head .040".
What carb is something complicated, because here You have two troubles: cost and smog. Smog is no problem, I'd use a Holley 450cfm, mec. secondaries. And a Clifford manifold. As for the cam, I'd use either a Clifford or a Isky supercam 266. You'll have to call them to grind this one for You, because I think they will not have one waiting for You.
This is what I'd done to a 292 if it were mine.
Alexandre Garcia
#36675 01/18/2002 1:33 PM
6t2Burb: The 292 is a good, strong motor. What we really need to know is-
How much performance?
What kind of mileage are you now getting?
Don't get me wrong, but a 292 will really perform when induced. But it will suck the juice too!!
For realistic everyday use on the street you kind of want to keep cost under control. If your engine has good compression there are four basic things that you can do to improve performance, and at the same time get the most bang for your buck, without increasing fuel consumption.
1.Overhaul/replace original carb with new (same)
2.Rebuild/replace distributor with new HEI unit
3.Add headers, change to less restrictive exhaust system than stock.
4.Meticulous tuning. This would include replacement of all ignition plug wires. plugs, tuning of carb, timing checks, valve timing checks, re-torque head, manifolds, cylinder leakdown testing, etc. Provided that your valves and springs are in good shape.
You would probably pick up a few horses 10/20 from where you are now, with marked improvement in fuel mileage.
The problems with adding aftermarket 4V carbs and new manifolds is you will just waste fuel. Without increased compression and increased breathing, the engine just simply can't use the fuel.
When you start talking about raising compression, higher lift camshaft, and all, then you start talking BIG BUCKS!! Additionally you will need new cam drive, 3 angle valve job, high pressure springs, etc. You can even get roller rockers and cam for this engine,.....But wait....that mileage was just killed!!!
When you price these parts out, like manifolds, carbs, cams, new pistons, rebuilding costs and all the other things you can think of... man it sure gets spendy fast. Yeah, you can have lots of ponies, but at what cost. And it won't be very streetable, or economical either. But what the heck, build your engine to suit YOU!! Only you know your needs, and budget! Repost.
Think Chevy! wink :rolleyes: smile
Houston? , We have a problem!
#36676 01/19/2002 6:49 PM
Anonymous
Unregistered
Anonymous
Unregistered
6T2burb, drop in on the inliners board and do a search on warming up 292's. Lots of good stuff. I can't tell you how many Clifford intakes and 3into1 headers I have seen in old trucks in the wrecking yards the last few weeks up in the Vanvouver area just a hop across the river from you. American Classics in Vancouver Washington has a 250 all set up with all the toys in a 66 pickup for $500, less than an hour drive from you. I am taking a 292 block and head into S&H over in Sylvan next week to have them go through it balance it and clean it up for my burb.
#36677 01/19/2002 9:48 PM
Junior Member
Junior Member
I agree with chevyman, except go to an 2x1 or 3x1 intake. Fuel economy won't suffer that much and it's worth the extra power.
65 GMC 910
250 C.I.D. 4-speed
#36678 01/22/2002 12:43 PM
One word on multi-carb set-up's: theu are much more difficult to tune than a 4bbl. And there is a wolrd of difference between the manifolds for 4 bbl. I've used the Okky and the Clifford. The offy is prone to unequal fuel flow in the head, some cilinders get rich, others lean. The Clifford is much better.
Here we had lots of manifolds for the 250 with 3 single carbs, they looked great, but worked poor. We used a lot the Solex H40/44 EIS carb , the one used in the kadron kit for VW flat 4 engines. About the same size as a Holley 1 bbl or any carter single barrel. And the solex has the diaphragm fuel pump, that never let You down, but milleage was always poor. The HEI is a very good choice, and also is inexpensive.
Alexandre Garcia
