7 members (SWEET, Donf, rfs56trk, sron48, 78buckshot, Wickedbass, JW51), 60 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#366630 01/27/2008 10:10 PM
There is water coming out tail pipe. Is it a blown gasket or cracked head.
mborth #366644 01/27/2008 10:20 PM
Ex Hall Monitor
Ex Hall Monitor
Maybe neither. You'll get natural condensation every time you shut the engine off and the exhaust cools. The water sits in the muffler/tailpipe and is expelled when you start the engine. The water boiling off is what causes the white exhaust in cold weather. If you get water in the oil you may have a bad gasket or cracked head. If it's only the tailpipe it's probably normal.
Tiny #366769 01/28/2008 1:14 AM
Like Tiny says. Are you losing any water from the radiator, besides overflow?
Larry
I don't own a vehicle that isn't old enough to drink.
