1 members (baldeagle), 107 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#36548 05/30/2003 4:17 AM
On my '62 GMC, there is the port for the oil pressure light switch to screw into on top of the oil cannister. On the opposite side, there is a plug that you can unscrew. It looks to be the same type of threads that are for the oil pressure switch. Is is possible to have the oil pressure light screwed into one of them, and an oil pressure gauge hooked into the other one? If not, what is this auxilary plug for? Right now, I have the mechanical gauge hooked in, but I would like the light as a backup in case the oil pressure drops too low.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
Jonathan - when I've had "idiot light" 60's 'bolts I just put a brass T in there and hooked both to the same spot - works fine - other plugs on the block . . . . no tellin! not much use for the light tho - when ya need it most is when it won't work! gauges are much preferable
