5 members (Gdads51, Wally / Montana, NJC, Otto Skorzeny, 1 invisible), 85 guests, and 2 robots.
Topics128,084
Posts1,056,334
Members48,442
#36531 01/09/2003 10:54 PM
W Online: Content
Here's what's stamped on the back of my 16 inch 8-bolt, gray, after market rims which I've been using on my '48 3/4T with 235-85-R16 Michelin highway treads for 6 years with no problems.
16x6K
CAP 3045 LBS, 80 PSI, DOT T
5 12 21
Rockwell Fumagalli, Made in Brazil
They are 6" wide. A tire man in town says the K has to do the the gauge of metal used. Some heavier rims have "KK" stamped on them according to him.
The set-back of the mounting surface to a straight edge spanning the furthest inside edge of the rim is 4 inches.
The tie-rod end on the driver's side sits about 1/8" from the rim edge. The tie-rod end is about 3/16" from the rim edge on the passenger's side. The steering arm is about 1/8" from the tire. This is a little close. But I've never had a problem whatsoever like I did with a 17x750 tire on a one-piece rim that was on the truck when I got it.
The picture in the 48-51 Shop Manual shows the tie-rod riding higher than mine and behind the brake flange plate. My tie-rod is pointing at the rim edge. If you get something like these, judge for yourself on your own rig. Hope this helps.
#36532 01/10/2003 2:35 PM
Wally, THX. I'll do some research and see what I can find.
#36533 01/10/2003 3:34 PM
Would a rim stamped 'KKK' come in white only?
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
#36534 01/10/2003 8:41 PM
Yeah. Mfg. in Pulaski,TN
If you think you can or if you think you can't, either way you're right.
