2 members (Wayne67vert, moparguy), 134 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
#364782 01/23/2008 8:58 PM
Does an O2 sensor measure actual oxygen in the exhaust mixture, or does it measure heat, assuming that the more oxygen means more heat. Reason for asking: on initial start-up, the engine blew a lot of raw oil out of the exhausts which seeped in apparently from an open valve cover. Every thing works ok now after warm up. Did the O2 sensor get clogged or damaged ?
Short answer, it measures the oxygen. The oil will eventually burn off. The sensor should be fine. On the other hand if you have a cat, that might cause some concerns.
I had purchased an engine/trans/wiring harness/rad/exhaust/etc that was involved in a roll-over. O2 sensors were fine, however the Cat did melt down because of the oil soaking. Your O2's should be fine, however if your engine starts to loose significant power, your cat may have ate itself
