1 members (1 invisible), 83 guests, and 3 robots.
Topics128,032
Posts1,055,519
Members48,425
#36313 05/11/2005 8:30 PM
I've been looking at some Edelbrock Torker II intake manifolds - they're supposedly a whole lot better than the stuck (ha, well duh)... So my question is, is it really worth it to get one of these? They run anywhere from $100-200 on eBay, and I'm thinking about it. Also, what are the benefits of these, do you get better gas mileage or worse?
305 V8, 4 bbl carberated.
GO RANGERS grin
Photos Updated so check them out!
#36314 05/11/2005 8:38 PM
H Online: Content
Edelbrock manifolds are probably no better, or worse, than stock, just different. If they're the dual-plane design, they duplicate the operation of a stock manifold, and give good low-speed to midrange performance. Single-plane manifolds are racing-only equipment, with major torque losses at low speed to gain a little top-end horsepower. Definitely stay away from a single plane manifold unless you're willing to give up breakaway torque and acceleration, and only plan to run wide open at high RPM all the time.
#36315 05/12/2005 4:15 AM
If you're wanting an intake for a driver, go with the Performer or EPS. The Torker II doesn't start producing power until 2,500 rpm.
Performance changes are minor, usually in the 2 to 5% range.
Fred
52 3600
69 C-10
#36316 05/12/2005 9:04 AM
Junior Member
Junior Member
check out http://www.edelbrock.com
they have all info you need.
and as stated before:single planes,are not for low end power,as in daily driving,I´d go whith the performer air gap,and an open air filter.
car nut for life!
