3 members (Hotrod Lincoln, DadsFirstPickup, Otto Skorzeny), 137 guests, and 4 robots.
Topics128,148
Posts1,056,810
Members48,454
I am adding fentons to my 235 along with a h/w carb and Langdons "heat plate". Since I am not running a heater at this time can I use the two outlets that would go to the heater as the "in" and "out" lines for the heat plate? If so does it make a difference which one goes "in" to the plate and which one goes "out" from the plate. (Guess that wasn't too quick of a question after all)
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
Yes, you may use the unused outlets.
No, it does not matter which goes in or goes out (it will circulate through the manifold either way).
Yes, it was two quick questions and these are two quick answers.
Tim
