| | | Forums66 Topics128,143 Posts1,056,786 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | I am adding fentons to my 235 along with a h/w carb and Langdons "heat plate". Since I am not running a heater at this time can I use the two outlets that would go to the heater as the "in" and "out" lines for the heat plate? If so does it make a difference which one goes "in" to the plate and which one goes "out" from the plate. (Guess that wasn't too quick of a question after all)
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, you may use the unused outlets.
No, it does not matter which goes in or goes out (it will circulate through the manifold either way).
Yes, it was two quick questions and these are two quick answers.
Tim | | |
