1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
#362396 01/18/2008 6:00 PM
My friend and I are having great difficulty lubing our king pins in my case the pins are new. I tried to lube them but the grease would not go in....I changed the nipples which was easy to my surprise..... I eventually got some grease in but it was hit and miss... I use the best grip gun etc.... the bottom bearing spins good.... I also had the front end jacked off the ground ..I noticed when I had the nipple off it seem to just butt up to the pin itself the grease seems to have no where to go....
any thoughts on this is ... I call it all part of owning a old truck...
Peter
Did you install the king pins?
Are the grease holes in the bushings lined up right?
Steve
'49 3800
'52 3600
'57 3100
That I don't know.... sorry
Peter,
Even if the pins are blocked by the bushings, you can remove the Zerk and run a drill through the bushing...it's bronze or brass and very soft. It doesn't hurt a thing if you drill into the pin a bit.
This will guarantee a path for the grease. Reinstall the new, good Zerk and pump away. As you drill, watch for the chips to change from brass/bronze to steel. That's when it's time to stop drilling. A small dimple in the new pin won't hurt a thing.
Cousin Stuart
atomarc #362467 01/18/2008 8:40 PM
Cousin what the heck is a Zerk is that something from space...
Cousin Peter
Just another name for the modern grease fitting.
34 & 35 trucks are the greatest
I thought Stuart was Zerking my chain....Peter
wave
Stuart
atomarc #362543 01/19/2008 12:21 AM
Riding in the Passing Lane
The 54 uses floating bushings. The grease should go through. You must have the truck jacked up so the weight is off the wheels. As you have pressure on the grease gun move the wheel back & forth a little. You can drill into the bushing like Stuart pointed out, but you will not drill into the pin. It is supper hard. Zerks have been around for 70 years.
1972 Chevy c10 Cheyenne Super
Peter, you had referred to them as "nipples". But zerk or zerk fitting is actually the proper name for them.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Thanks for all the ideas here again at least I know what a Zerk fitting is....Peter
