| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 23 Apprentice | | Apprentice Joined: Aug 2007 Posts: 23 | I have one of the borg warner 3 spd overdrives to go in my 54 , I know back in the day they made a 3 spd floor shifter that the linkage would get around the soloniod and that there was a special name for them that I cannot remember . I have looking for one but it makes it ten times as hard without the name . Can anybody help ? | | | | | Joined: May 2007 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 95 | | | | | | Joined: Jan 2001 Posts: 1,423 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,423 | You can make your own transmission attachment bracket that ends up with the shifter in the middle of the floor. Here's the bracket I made. Notice the up-over-up I made out of 3/8" steel. Here's the bent shifter arms that clear the solenoid. Notice that I not only shortened the shifter dogs on the shifter plate but welded them on. By shortening the radius I shortened the overall shifting distance between the gears. It still has the traditional 3 speed 'H' pattern. Finally this is where the shifter ends up... in the middle of the floor.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
