| | | Forums66 Topics128,161 Posts1,056,906 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 23 Apprentice | | Apprentice Joined: Aug 2007 Posts: 23 | The title pretty much says it all except what motor its going on , its a 235 . the end of the crank does not have a threaded hole in it . I dont want to use a hammer , it just cant be right . | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | A good set of welding gloves, and your oven. Set it to 200F Bake for about half an hour
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A lot of people say what Scott does but I'm uncomfortable with the idea of getting rubber that hot. I used a BFH & steel bar to drive mine on. Just strike it on the hand crank lugs so you don't damage the balancer.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It is made to go on with force. The problem is trying to figure out when it is home. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I;m with Scott. I did mine at 200 for 15 minutes, then knocked it on with a mallet.
It probably gets close to that hot once the motor is shut off after a long drive.
I was worried more about damaging a crank seal pounding it on even though I know guys do it all the time.
I lined mine up with the other pulleys to know when it was in the right spot. | | | | | Joined: Jan 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 56 | I'm with Scott too. It can handle 200 degrees and a BFH works well too. Make sure the welding gloves aren't greasy, they will heat up fast and the smoke will get in your eyes, preventing accurate installation
You can take the girl off the farm, but you can't take the animals out of her truck. Watch the build of my 1954 Chevy at www.v8tvshow.com | | |
