2 members (Danielbolt, Hotrod Lincoln), 68 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
Q
Apprentice
Apprentice
Q Offline
The title pretty much says it all except what motor its going on , its a 235 . the end of the crank does not have a threaded hole in it . I dont want to use a hammer , it just cant be right .
A good set of welding gloves, and your oven. Set it to 200F Bake for about half an hour
Ex Hall Monitor
Ex Hall Monitor
A lot of people say what Scott does but I'm uncomfortable with the idea of getting rubber that hot. I used a BFH & steel bar to drive mine on. Just strike it on the hand crank lugs so you don't damage the balancer.
It is made to go on with force. The problem is trying to figure out when it is home.
1951 1 Ton Completed
I;m with Scott. I did mine at 200 for 15 minutes, then knocked it on with a mallet.
It probably gets close to that hot once the motor is shut off after a long drive.
I was worried more about damaging a crank seal pounding it on even though I know guys do it all the time.
I lined mine up with the other pulleys to know when it was in the right spot.
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
V
V Offline
I'm with Scott too. It can handle 200 degrees and a BFH works well too. Make sure the welding gloves aren't greasy, they will heat up fast and the smoke will get in your eyes, preventing accurate installation grin
You can take the girl off the farm, but you can't take the animals out of her truck.
Watch the build of my 1954 Chevy at www.v8tvshow.com
