| | | Forums66 Topics128,115 Posts1,056,294 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If I get a 3rd member from a 67-72 3/4 ton to put in a 52 can I be reasonably certain it will be 4.11 or even possibly a 3.90. Thanks George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | George, I have no additional data to confirm the accuracy of this vendor's info, but here are the axle codes for the 67 and 68 Chevy trucks. Should help to guide you in your search. http://www.gmcpauls.com/67-72_chevy.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | No. Just as likely to be a 4.57. It's real easy to tell the ratio by jacking up a tire and spinning the wheel and counting the wheel turn to drive shaft turn, then getting the ratio. You don't have to be dead on. It'll either be 5.13 (not original to that year and model) 4.57 or 4.11. Destiny is never so nice that it would be a 3.90. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | There were no 3.90's made for the 3/4 ton Eaton axle. There were a very, very few models that had a 4.11. Been lookin' for over a year and haven't had one single bite. Where there is a demand there should be a supplier. I can't for the life of me figure out why one of the gear grinders hasn't set up for one that will fit the 3600 AD's. I don't know anyone that has a 3/4 ton that doesn't want to go with a higher gear than the 4.57. Oh, maybe there are a couple but that would be 1 out of 10,000. Good luck! Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The rearend gears that you want are 4.10 and if you count the teeth on the ring, there are 41. The description that I hear over and over is 67 to 72 3/4 Ton with automatic and coil springs. The reason for mention of coil springs is because there were some Danas used with the leaf spring setup. I put one from a 71 in my 51 1 Ton and it cruises nicely at 50 mph, which is what I want with my original 216. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Denny, looks like you're going to have to break down and upgrade to something more modern if you want to run cruise at 55/65 mph.
~Jim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Nope Jim, the only thing more modern that’s goin in my rear end is a gear. I’m not changing the housing. I know they are out there I just have to find one. Of course by the time I find one I could be so old that I won't want to drive over 45-mph. With a stock 216 I doubt if it could pull anything higher than a 4.10. And I stand corrected Fred, your absolutely right on the ratio, force of habit from the old drag race days you know. I see where some of the guys have gone on a nation wide search to find one. I just hate to think about going to all the trouble of having a carrier shipped from Oregon to Chicago and finding out when it gets here that it's not the right one or that the gear set is shot. Denny Graham Sandwich, IL
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Thanks for the help fellow bolters. I know what to look for now. My partner has a salvage lot. He is going to get one this weekend. Denny, if he has more then one would you be interested in one? George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
