1 members (Hotrod Lincoln),
112
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36098 10/22/2004 12:54 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Hi-
I was wondering if there is any difference in the rocker arm assemblies from 1954 -> 1962 other than the oil dump (the pinched pipe) I thought the only thing that was different in the heads was how the valve cover was attached.
Mine are worn and I'm looking to replace them. I have a 54 engine with a 55 and up head, or at least I think the heads are the same 55->62 ??
Is my thinking correct??
Brent | | |
#36099 10/22/2004 1:53 AM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | Brent, I have two heads here. Casting number 3835913(1954 to 56ish?) and the "higher" compression 3836848(1957-62). FWIW, After a careful look, I see no difference in the rocker rack, other than the oil dump you mentioned. | | |
#36100 10/22/2004 8:34 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | There are at least two different part number sets for the rockers. The rockers on my 848 head are different numbers than some earlier heads. Arms are shaped a little bit different, iirc. But they are interchangeable.
Fred 52 3600 69 C-10
#36101 10/23/2004 5:25 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There were subtle differences through the years but the main difference took place in 1959 when the groove inside the rocker was moved 1/4" off center so it did not line up with the supply hole in the shaft. That and the pinched off supply tube pressurized the oil supply in the shaft.
See the USA in your vintage Chevrolet! My Blog | | |
#36102 10/23/2004 1:47 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | They changed the way the oil gets up to the rockers I think it was 1958.
On earlyer engines you have a pipe going thru the side cover. Later engines used different lifters (with an anulus)and the oil comes up via a passage in te block.
If you have a later engine and head, the rockers are different. They have a offset oil groove at the bushing in opposit to a centered one on the earlyer models.
If you use the older rockers (with the centered groove or anulus)they flow much more oil and you get a big oil mess out of the valve cover.
SO...
if you use a post 58 block and head with anulus lifters an the oil line in the side cover you need the offset anulus rockers. Also you don`t want to have the overflow pipe between the rockers.
if you use a pre 58 block and head with the oil line and the straight tall tulip style lifters, you need rockerarms with the centered oil groove and a overflow pipe between the shafts
if you got a -lets say- 59 block and a 55 head GM service shops used a hollow head bolt for this combination - and it is getting a bit complicated.
hope that helps, Frank | | |
#36103 10/29/2004 3:54 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Thanks for all the input, So I guess they are different. So the next question is if your rocker shaft and arms are not worn at the pivot. Is it common to have the rocker tips ground? If the rockers weren't so darn expensive the prefered method is to replace them. BUT.... not the case anymore.
Brent | | |
#36104 10/29/2004 7:35 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | With mechanical lifters, you need to grind the rocker tips every time the rockers are off the head, if the are showing signs of wear. What happens is the tips get dented from the valve, and then you can't accurately adjust the valves.
