5 members (gswbbc, Eisenholtz, 50Chevy3100, Bill Hanlon, 3800GUY), 101 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#357460 01/07/2008 3:45 AM
I'm in the process of replacing the rubber transfer case mounts on my '60. I removed the eight 9/16 bolts that were holding the mounting brackets. I noticed that they were fine thread number 5's. Is there any reason I couldn't replace these bolts with number 8's coarse thread bolts? Why did the manufacturer use the fine threads? I know that the number 8's are stronger, but are they not as flexible or maleable as the number 5's?
The mounting bracket bolts should be fine with either grade 5 or the 8's.Yes the 8 is stronger and I'm not even sure there was a grading system for bolts in 1960 so the 5 was the bolt of choice.The fine thread bolt will give you more holding strength due to the threads per inch so they would be my choice.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
Grade 5's stretch a bit before they snap compared to grade 8. Grade 8 has more ultimate strength but grade 5's fail more gracefully. I would replace with fine thread bolts.
Paint & Body Shop moderator
Thanks guys.
I went with new grade 5, fine thread bolts. I figured this type of bolt lasted 48 years without fail in a truck that was heavily used and abused. I just hope the quality of the bolts today match the quality of the bolts back then.
