7 members (Dennys28, klhansen, walter74, Lightholder's Dad, Millenimech, Wayne67vert, 1 invisible), 139 guests, and 4 robots.
Topics128,209
Posts1,057,462
Members48,471
I am looking for a set of cab lights, vintage, not new.
Hopefully, someone has a set that is sitting on a parts truck outside.
I am looking for PATINA, not shiny chrome....the duller the better.....mind you, not rotted and/or pitted...
DEFINITELY want glass lenses and metal frames.
FIVE would be great, THREE is okay.
A good used set that will match my old truck...
http://i5.photobucket.com/albums/y165/mgcarma/61%20Apache/DSCN5400.jpg
Yep, she's a BEAUT!
Don't have any, but i can give you a suggestion on where to look. Find a slavage yard that has alot of older big trucks, like 1 1/2 ton an bigger. Almost all of those shoulf have the lights you want, just look for a similar year range truck. Be warned, though, that most likely, the bases will be totally rotted, and the sockets most likely will not work. But if you're handy enough, one could make new bases (they can't be seen with the chrome part in place.).
Bill Burmeister
i just got a set of three (arrows) today myself that are in great condition. what im looking for is where do you find good gaskets.
You'll probably have to make them yourself. So far, no one is repoping the old cab lamps or gaskets. Shouldn't be too hard, just get a sheet of 1/8" rubber, use the base as a pattern, and cut them out. Might need a hole punch to do the screw holes.
Bill Burmeister
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Type in "Cab Lights" into the ebay search engine && you'll find a few. I even seen "NEW" ones for sale on the page I seen. O the heck w/it check you PM's for the page I seen...Joe
There is a pair of them on the Mr. Haney page of the fifthaveintrnetgarage.com website. Maybe those would work>
if any body lse needs them i found them at arrow safety device company site. they have the gaskets for the lens and the bases.
