| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#3601 12/15/2003 11:00 PM | Joined: Aug 2001 Posts: 44 New Guy | | New Guy Joined: Aug 2001 Posts: 44 | I have a 51 - 3100 that I am converting to a dual MC (GM type) for front disc brakes. The adapter kit includes an adjustable rod for connecting the MC to the brake pedal. What is the correct way of adjusting this rod?
41 Chev 2dr coupe 51 3100 w/a 261 11 Camaro RS ragtop
| | | | | Joined: Jul 2003 Posts: 55 Member | | Member Joined: Jul 2003 Posts: 55 | Are these going to be be power disc brakes? I'm not going to be able to help with your specific application, but here is some info. The rod length will give or take away mechanical leverage. When my instructor put power brakes on his Nova, he left the rod in the same location as non-power brakes. His brake pedal arm had two holes drilled in it. A lower one for manual brakes, and a top on for power brakes. Anyway, he hooked it all up and went for a test drive. If you even thought about touching the brake pedal the car would screech to a stop. Power brakes won't require all of the mechanical leverage that manual brakes do. You might have to try it out and fine tune it from there. Sorry, I can't help more. John.
1968 Chevy C-10, 250 and 3 speed on floor, Hedman headers, Offy intake, Edelbrock 600cfm 4 barrel, HEI 1966 Chevy C-10, motor and tranny went into the '68. Waiting to be restored.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I think it should be adjusted just like the old brake rod was, 3/4" (I think) of pedal play before the MC moves.
