| | | Forums66 Topics128,209 Posts1,057,462 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 94 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 94 | I am looking for a set of cab lights, vintage, not new. Hopefully, someone has a set that is sitting on a parts truck outside. I am looking for PATINA, not shiny chrome....the duller the better.....mind you, not rotted and/or pitted... DEFINITELY want glass lenses and metal frames. FIVE would be great, THREE is okay. A good used set that will match my old truck... http://i5.photobucket.com/albums/y165/mgcarma/61%20Apache/DSCN5400.jpgYep, she's a BEAUT! Kevin | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Don't have any, but i can give you a suggestion on where to look. Find a slavage yard that has alot of older big trucks, like 1 1/2 ton an bigger. Almost all of those shoulf have the lights you want, just look for a similar year range truck. Be warned, though, that most likely, the bases will be totally rotted, and the sockets most likely will not work. But if you're handy enough, one could make new bases (they can't be seen with the chrome part in place.).
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i just got a set of three (arrows) today myself that are in great condition. what im looking for is where do you find good gaskets. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You'll probably have to make them yourself. So far, no one is repoping the old cab lamps or gaskets. Shouldn't be too hard, just get a sheet of 1/8" rubber, use the base as a pattern, and cut them out. Might need a hole punch to do the screw holes.
Bill Burmeister | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Type in "Cab Lights" into the ebay search engine && you'll find a few. I even seen "NEW" ones for sale on the page I seen. O the heck w/it check you PM's for the page I seen...Joe | | | | | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | There is a pair of them on the Mr. Haney page of the fifthaveintrnetgarage.com website. Maybe those would work> | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | if any body lse needs them i found them at arrow safety device company site. they have the gaskets for the lens and the bases. | | |
