| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | I am wondering if 51 chevy parts will fit on a 54 GMC? Are the body and frame the same, or not at all? Just wanted to ask you stovebolt guru's, before I buy something I can't use. Thanks These are both 1/2 tons also.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are significant differences (but a few interchangeable parts), if you were comparing 1954 Chevrolet & 1954 GMC.
But, if you are looking for parts for your 1951 Chevrolet, the 1954 GMC is not a good choice for a parts truck (and visa versa).
My vote: not a good match.
Tim
| | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Thanks for the reply. I kind of figured that, but wanted to be sure. Thanks again. Tim | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The frames are not the same, the front fenders are not the same, the grilles are not the same the cabs are not the same, the beds are not the same. But on the other hand if the 54 is in good condition, the front clip from a 51 Chevy will fit, the door catches will have to be changed to accept the earlier doors and the engine cross member may need to be modified to fit the chevy components ( this may mean modifying the radiator to accept the longer GMC engine)
54 sheet metal is a little bit harder to find in good condition than the 48/53 fenders. Look in the gallery to see some of these differences. | | |
