| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35786 01/20/2005 10:01 PM | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | I'm generally pretty adept when it comes to wiring/electrical, but the horn relay hookup has me scratching my head. I've found information on how to wire the relay (left pole to horn, center pole to battery, right pole to horn button), but I'm stumped as to wiring the actual horn. It has two poles/connectors; I'm assuming one is positive (+), the other negative (-). However, there is only one wire leading from the horn to the relay. So...what hooks up to the other pole (on the horn)? I assumed it connected to a ground...however, when I do so, it completes the circuit and the horn sounds. I've tried every variation I can think of, but to no avail...at present, I've hooked up the horn directly, without a relay. However, I understand that's not the best (and safest) way to go.
Any help/suggestions would be greatly appreciated.
Thanks! | | |
#35787 01/20/2005 10:29 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The relay grounds through the horn button. That closes the contacts & sends power to the horn.If the horn has 2 terms. yes you would ground one. If it blows you either have the relay wired wrong or it is defective. I,m not shure if it,s nessesary to have the relay grounded but won,t hurt.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#35788 01/21/2005 2:40 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The horns with two connectors do not use a relay. One is hot all the time the other goes to the horn button to ground the circuit.
See the USA in your vintage Chevrolet! My Blog | | |
#35789 01/21/2005 4:34 AM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | I used a relay on mine, and I just made the relay ground through the horn button. I suppose you could just not use a relay but it seems like the intermittent connection might damage the horn button components quickly with such a large load going through such a delicate component.
1948 3600 thriftmaster
