| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | In my 49 Chevy the thermostatic valve seals went and leaked antifreeze all over my flooring in it. I have replaced the valve and now am in the process of trying to figure what to clean it with. Its is a car first off secondly its is some type of frail rubber where it has been stained the most. I tryed mild soap and water no go so far. Wondering if you have anything ideas how to clean it with out destroying the flooring. The entire interior of the car is orginal and in near mint condition accept the flooring and I would like to keep it that way. Also what do you use to detail the rest of the interior. I kinda of hestitate using alot of cleaners. To afraid that it will damage the car. Any advice? | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Is this a black rubber floor mat your wanting to clean? If it is and you can not get it clean you can probably paint with black tire paint. | | | | | | Dave Giorgi Unregistered | | Dave Giorgi Unregistered | Delux,
Just clean it as best you can with the mild soap and spray it with vinyl paint color to match the original color.
Dave
