Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (Gdads51, 68ironhead, wilbur53, 3B, TUTS 59, 1955 1 Series, mick53, RdsLessTaken), 101 guests, and 3 robots.
Topics128,281
Posts1,058,473
Members48,490
Have a fresh Rochester 1 brl on my 250 and since the truck (67 panel) did not come with a cleaner and one brl air cleaners hard to find, I installed a "mr gasket" plastic adapter and stadard 10" chrome air cleaner.
Therin is where the trouble lies...It's sits too low, and is in the way of the choke mechanism, can I fab. somthing out of PVC?(the adapters plastic) ....or will it melt!!??
Just wonderin if its a harware store or Machine shop issue.
:p
Douglas,
Hope you had a wonder Christmas in Lovely Soquel. Don't know much about your clearance issue but I would steer away from PVC for both stability and durability reasons. I'd be a little concern with the affect the heat from the engine might have on pvc after your stopped. Maybe I'm a little over cautious. I'm sure you can either find or configure something in metal instead that would be a lot more stout.
Craig
Craig
I had a difficult time getting an aftermarket air cleaner to fit the top of my Rochester 1bbl carb on my 37 Chevy pu w/56 235 engine. I ended up going to Winchester Auto Parts in Soquel and getting a tailpipe adapter and cut it down to fit. Just measure the opening in the air cleaner and the top of the carb & get pipe that fits. If they don't have it in stock, they can order it and have it there in a few days.
1937 Chevy pickup
1952 MGTD
Douglas, toclarify, I meant exhaust pipe adapter, not tailpipe adapter. Hope this helps you. Charles
1937 Chevy pickup
1952 MGTD
Douglas, I was just working on a 69 GMC with a 305, I'm going to scrap. It has a spacer on the Stromberg that will fit your Rochester. The spacer is 7/8 in. high, if that will work for you, email me your address, or you can pick it up. I'm over the hill in San Jose. You can have the air cleaner if you want it too.
Larry
68 C20 327 daily driver
63 C20 292 Camper truck
65 C10 ? Custom Cab AC,PB,PS,$flasher
I don't own a vehicle that isn't old enough to drink.
Quote
Hey Thanks Neighbor! I'm about 250 yds from Winchester auto! I'll check that out as an option,
One question though, I will need it to be diferent sizes on each end since it need to be an extension riser going from the carb to the spacer. :p
Quote
Larry
I will drop you a line. grin
If the top of the air cleaner is causing the clearance problem why not just use 2 elements. That will solve the clearance problem and let the engine breath a little easier.
Quote
Sorry It's the BOTTOM of the cleaner clearing the choke.
Douglas, I have the adapter for my carb in my garage, it is different sizes at both ends. It is a reducer to go from 1 pipe size to another. I found a stock 37 air cleaner that fits without it, so it is collecting dust in my garage. If you can use it, you can have it. I'll have to measure the sizes. Winchester stocks lots of them in different sizes at both ends and can order sizes not in stock. I'll measure mine. If you want it, contact me @ [email protected].
1937 Chevy pickup
1952 MGTD
Hey, I have an extra air cleaner, will anyone give me a truck to go under it? I am right over that hill too...
smile
54 3100 with 235
62 flatbed dump C60 with 261
Hey all you stovebolters, thanks for such sage advice and outpouring of generosity. I ended up doing the muffler pipe trick.
Went to Midas and they took care of me with a small scrap of pipe. Took it home and ground it smooth. Voila!! Eureka! etc. etc.
-Douglas
