2 members (KEVINSKI, 55shaker),
125
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 12 New Guy | | New Guy Joined: Oct 2007 Posts: 12 | This is kind of a saga but here it goes: My '54's carb was in bad shape when I bought it. I rebuilt it the best I could, but it didn't hold. I ended up buying one off ebay. It was in pretty good shape, except it was all froze up with gunk (varnish?). I tore it down totally and rebuilt it. It ran good for a while but today it began flooding out. I have gas pouring out of the top side of the carb. This is the same problem I was having with the original carb. I'm not sure where to focus. The float seemed correct when I set it. Someone suggested I back that off a bit. I'm wondering if it may be the accelerator pump sticking. Any carb experts out there? Or has anyone been through the same issue?
Rick
UPDATE: Thanks guys. The method of pinching off the fuel line to clear the needle valve seems to have done the trick for now. I'm not going to run her again until I get new fuel filters. Since the tank is almost empty now, I'll probably just drain it in hopes of getting at least some gunk out.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | With gas coming out the top, it's definetly a float level issue. The float level is too high.
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rick,
Could there be a chance that your problem might be further upstream. If there is junk in the tank, and it makes it to the needle and seat, it can hold it open and cause the problem you describe.
I only mention this because you said it happened on the first carburetor too.
The brass float assemblies can spring leaks and sink. When you take you carburetor apart again, make sure the float isn't full of gas.
Stuart | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | | | |
