First, I know this isn't really a driveline issue, but I got virtually no response over in the lounge (maybe cause it has nothing to do with politics?
) so I thought I'd try over here amongst the mechanics.
This is on a 53 Chevy 3/4T. I'm getting ready to reinstall the brake and clutch pedals on the pedal shaft. Currently, they both still have the old bushings which don't appear to be worn, though I am going to replace the bushings while they are off. Right now I'm test fitting everything on the bench after cleaning. The pedals slide easily part of the way onto the shaft and then stop. Should they slide all the way to their final position? How tightly should they fit on the shaft normally? Should they slide on or will they need to be pressed on? It seems to me that they should slide on since they need to rotate on the shaft easily when the pedals are depressed, but then I've been wrong on many things in the past.
Any thoughts or comments would be greatly appreciated.
