1 members (baldeagle),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | Someone just gave me a Harrison HD-206-50 heater for my 1952 Chevy 1300.I have been cleaning it up. It looks like it will just bolt right in. It is the fresh air model. I would like to test this befor installing.My truck is now a 12 volt system . Should I use some kind of resistor? Also Where did they locate the on / off switch? Did the heater knob have an "H " ? Do most people rig up a turn off valve to shut off the water flow in the summer? Any help would be appreciated. Happy New Year ! Jeff | | | | | Joined: Mar 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 65 | I bought a Harrison heater, but had to replace the motor since it was shot. Since I had converted all electrical to 12 volts, I just bought a 12 volt motor and switch from Jim Carter Classic Truck Parts. I mounted the lighted rotating switch in an open hole below and to the left of the glove box on the dash. The heater really moves some air after I switched the fan blade and hub to pull air through the heater core. | | | | | Joined: Mar 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 65 | Since I was not keeping it original, I put some valves in the heater hose line so I could turn off the water flow to the heater during warm weather. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A lot of people put shut off valves on the heater hoses for summer time use. Many used the under dash rheostat motor control for the heater. My 55 panel had that type of switch.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It would be easier in the long run to just by the 12 volt motor and put it in. About twice a year I have to replace the rheostat on my 1942 Ford tractor that was converted to 12 volt.
~Jim
| | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | Thanks for the advice guys. I'll probably go the 12 volt motor route. Jeff | | |
