8 members (GA Boy, 2-Ton, Gray_Ghost, Nick in Manitou, GMCJammer51, Joe H, Andrew_Julio, Jay R),
75
Mod | | | Forums66 Topics128,169 Posts1,057,033 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 30 | Could someone give me a rough number on how many 60/61 c-30 or greater trucks were made? did the 1T+ trucks have a 4X4 option? What was the highest weight ration before the truck went to the bigger commercial body style? Last of all, is there a way to make heavy trucks get better gas milage? I was having another thought today on the 61' wrecker I wanted to create, and I wanted to know some stuff about the production of heavier apache's. What is the suggested rating for a wrecker other than a regular C-30? | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | If you like '60-'66 Chevy Wreckers. Here's one I sold a few years ago. It's a '65 Chevy LCF L80 series, that was rated at 34000lb. gvw. It had a 409 Chevy Big block engine, 5 speed trans., with a 2 spd. rear axle. It also had power steering, & full air brakes. That's a Holmes 600 Wrecker unit, on it's back. http://rides.webshots.com/photo/1116214364052570246oIGbJw | | | | | Joined: Mar 2005 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 30 | I prefer the 60/61 for the hood and dual headlights. I saw a picture of a 1961 chevy wrecker and fell in love with the truck, but I can't find that picture again thanks to my luck. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Yeah, I had one of them also. It was a 1960 Chevy L80 LCF, with 348 big block V8, 5 spd. trans., & 2 spd rear axle. It was a 27000lb. gvw truck. It also had power steering, & full air brakes. Check out this site, & scroll down until you see it(3rd set of pictures). http://www.classiccoe.com/oldcoetrucks/6066.htm | | | | | Joined: Jul 2006 Posts: 8 Junior Member | | Junior Member Joined: Jul 2006 Posts: 8 | i have a 61 apache 30 and apache 40 ,1 1/2 ton rated 15000 gvw.mark | | | | | Joined: Mar 2005 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 30 | I have found a great truck to be my wrecker! Behind some guy's house is a 60/61 2T or greater dump truck, and it look's pretty solid. I suspect they are not doing much with it, because they have a few older thing's just sitting around in their yard (such as a older dodge panel truck). I first noticed thsi truck a few month's ago when my CV-TEC bus went by the house, and I just happened to be looking out the window. I am going to see if we know anybody related to those people, and see what happens from there. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 |
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Mar 2005 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 30 | I am not certain here, but were the mediaum duty truck's in the 50's - mid 60's called viking's? Also, would the frame length of a dump truck be different from a wrecker? Any answers are wanted, and I thank you for them! | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The Viking name was used on Medium Duty Trucks from 1958 -1961. The Heavy Duty Line, in these same years were called Spartans. | | |
