eb1: check with-
1. Crane Cams 904-252-1151
2. Lunati Cams 901-365-0950
3. Competition Cams 901-795-2400
They should be able to fix you up with everything you need from studs, rockers, valves, pushrods, cam and lifters. The 292 stud/rocker arrangment is the same or very close to a SB Chevy in layout and geometry. Worth a shot, anyway. If they do not have a set-up for the 292 specificly, they will probably have something very close that can be modified to fit your needs. Good Luck!
Think Chevy!
:rolleyes:
