| | | Forums66 Topics128,162 Posts1,057,058 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 26 Apprentice | | Apprentice Joined: Jul 2006 Posts: 26 | Does anyone have the wheel mounting to wheel mounting measurement for a 46 Chevy 1/2 ton rearend??? Any help would be appreciated.
Thanks | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Don't quote me, but I believe it is about 59... at least that what I figured my 1940 to be. I got an IMCA modified 9 inch for mine and spec'd 12 inch 6 lug disc brakes for the rear. I also spec'd the width to be 61" wheel to wheel.
There is about 11 inches of fender on the 40- 46 1/2 and 3/4 tons. The bed should be 48 1/2" wide. 61" in theory should center the wheels under the fenders if you are using a 7 inch wide rim with 4 inches of backspacing, or a 1 inch offset inward.
I plan to run either 245/70R16 or 255/70R16 tires on the rear of my 1940. I believe that the 255 (10.2" wide) tire will fit, but it will be tight. I HAVE NOT MOCKED ANY OF THIS UP TO SEE IF IT WILL ACTUALLY FIT. Take your own measurements, and do your own Math, as mine has been known to be a little bit off. | | | | | Joined: Jul 2006 Posts: 26 Apprentice | | Apprentice Joined: Jul 2006 Posts: 26 | Thanks for the info....
I did some more measuring today and found that the overall width fender to fender is 71 inches and that the fender openings are about 11 inches. I think that I am going to order a rearend that is 60 inches total width(wheel mounting surface to wheel mounting surface). This should put the wheel mounting surface in the center of the fenders. | | |
