| | | Forums66 Topics128,208 Posts1,057,448 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 26 | I have a 3/4 ton 65 Chevrolet truck. I'd like to put better gears in for a higher highway speed, and I'd like to use 6 lug wheels. Unfortunately, it doesn't have a Dana, because there are gears available for those differentials.
Basically, I'm thinking about turning it into a 1/2 ton.
Have any of you ever done this? If I put in a 12 bolt, is the driveshaft the same?
Is there any way to put just 1/2 ton spindles on 3/4 ton A-arms?
Any thoughts in general on making the 3/4 more driveable?
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I can certainly understand were your coming from. I have a 63 3/4 with an Eaton and 4.11 rear axle ratio. I pulled the sm420 and replaced it with a A833, 4th is an overdrive. The drive shaft had to be shortened a little over 9 inches. Problem solved now instead of 3300 at 65 I'm doing 2300.
Now do you also want to soften the ride by going to 1/2 ton suspension? If so I would say find a donor truck and swap everything over.
ttt
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | There are plenty of 8 lug wheels that will work and look sporty on your truck. If you want a 1/2 ton instead of a 3/4 ton, TRADE! It will be less work.
Without changing the gears, you can do much better by installing an overdrive, or an overdrive transmission. An A833 as mentioned is a great choice as well as an NV4500 5 speed. Both of those transmissions have a 0.73:1 final drive, which will cut your rpm by 27%. Both are stout transmissions. The NV4500 has the advantage of having a granny gear for getting those heavier loads rolling. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I looked into the whole rear end swap out a while back for a for a project and it ended up being cost prohibitive. It is possible to change both front & rear components with a 1/2 ton. I have seen them done but it would be helpfull to have a donor truck and you are still getting 40+ year old parts. I'm partial to OD's, and have installed them in numerous vehicles. A whole lot less engineering and work than changing all the other components. Like the other guys mentioned there are a lot of choices out there. I had a 66 C-20 with a 292 and 3 sp OD that I drove for 17 years, daily driver, work truck, hauled a camper, and able go anywhere at freeway speeds. Fred
| | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | I'd like to follow up on the A833 issue. My truck has a T5 with a 4:1 first gear, and it's like a granny gear. The gears in an 833 seem very attractive to me. In studying the threads re: 833 I gather that the Mopar trans have a different bell-housing pattern than GM's. This seems logical, but can one of you confirm ? Thanks in advance | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Your correct the 833 for the Mopars does have a different bell mount. What I used was from a 82-87 Chev truck that was installed under the RPO MY6, that why it is also called a MY6. The biggest problem was finding a shifter for it, since I didn't get the oem Hurst that came with it. In my 63 the shifter came up left center, 4-6 in front of the seat. To confuse things GM made a bell housing with the Mopar bolt pattern on it, they are very rare. I've seen two of the dual bolt pattern bells on that auction site in the last 4-5 years.
Forgot to mention you need a bell from a 68-72 truck or machine your bell out to 5 1/6(?) for input bearing retainer. The 833 input bearing retainer is the same size as the sm465.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | Thanks, LG. I should be OK w/ my bell since the engine is from a 71 truck, but I'll measure before lifting the trans into place, and wondering why it won't fit | | |
