6 members (Shade Baby, TexasA&M48Truck, tclederman, Hotrod Lincoln, Bill Hanlon, 1 invisible), 82 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
I recently purchased a 1941 Chevy 3/4 ton pickup, it's in good original condition (6-volt) and runs. I want a truck I can drive more often than in local parades, and I now realize the limits the 6-volt, 216 with 4-speed (non-syncro) transmission. I would like to swap out the engine and tranny to something that is still classical (carb) but more modern. I've heard that the Chevy T-5 transmissions will mount up to a 235 and 264?
Advice? Lessons learned?
Working on the kids truck up this way and we are going to keep the original set up as far as the drive train. will go to a 12 volt. nothing wrong with the original set up just don't be in a hurry to get there, He plans on using it as a daily driver in Huston.
Drive with Pride. mike j
family pic
Dump the 216 for a later model 235 with dual carbs & fentons, upgrade to a 12 volt system & do the T-5 swap. thumbs_up
Robert C.
I'm a Genius in the making.
1950 3600
Robert C.
1950 3600
Dump the 216 for a later 235 with a heated Clifford manifold and a 390 cfm 4-barrel carb and Fenton dual exhaust.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Jim...I have a '42 PU...put a '60 235 w/ a T5 and a 3.42 rear. With two (2) 2bbl Carter Webers on a Offy intake w/ Fenton Headers/ dual exhaust it is a fine running truck. I did convert the rear axle to one from a '70 Nova.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
Are you relly going to do these modifications so you can drive it in local parades? Most parades I have seen are conducted at walking speed!
1951 1 Ton Completed
I would be interested in the 216 and tranny when you swap. Let me know.
Rob
I have swapped from 216 motor to 235 motor and put my original cluctch, bellhousing and tranny on 3/4 ton truck, engine sounds good, just little glitch in my tranny need to figure that out.
Rob
I have 1952 216 running motor swapped to 235, let me know if you need it, sorry Jim I saw this message couldnot resist to tell him
Ganesh
