| | | Forums66 Topics128,094 Posts1,056,483 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 15 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 15 | I recently purchased a 1941 Chevy 3/4 ton pickup, it's in good original condition (6-volt) and runs. I want a truck I can drive more often than in local parades, and I now realize the limits the 6-volt, 216 with 4-speed (non-syncro) transmission. I would like to swap out the engine and tranny to something that is still classical (carb) but more modern. I've heard that the Chevy T-5 transmissions will mount up to a 235 and 264?
Advice? Lessons learned? | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Working on the kids truck up this way and we are going to keep the original set up as far as the drive train. will go to a 12 volt. nothing wrong with the original set up just don't be in a hurry to get there, He plans on using it as a daily driver in Huston. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Dump the 216 for a later model 235 with dual carbs & fentons, upgrade to a 12 volt system & do the T-5 swap.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Dump the 216 for a later model 235 with dual carbs & fentons, upgrade to a 12 volt system & do the T-5 swap.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Dump the 216 for a later 235 with a heated Clifford manifold and a 390 cfm 4-barrel carb and Fenton dual exhaust. | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Jim...I have a '42 PU...put a '60 235 w/ a T5 and a 3.42 rear. With two (2) 2bbl Carter Webers on a Offy intake w/ Fenton Headers/ dual exhaust it is a fine running truck. I did convert the rear axle to one from a '70 Nova. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Are you relly going to do these modifications so you can drive it in local parades? Most parades I have seen are conducted at walking speed! | | | | | Joined: Apr 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 37 | I would be interested in the 216 and tranny when you swap. Let me know. Rob | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I have swapped from 216 motor to 235 motor and put my original cluctch, bellhousing and tranny on 3/4 ton truck, engine sounds good, just little glitch in my tranny need to figure that out.
Rob
I have 1952 216 running motor swapped to 235, let me know if you need it, sorry Jim I saw this message couldnot resist to tell him
Ganesh | | |
