3 members (WICruiser, 2 invisible), 142 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
#35244 09/18/2003 9:31 AM
Chips oil pressure post got me thinking about hooking up an aftermarket guage to my 250. I know I replace the electric sender with the one for the guage. My question is... do you let oil into the line before you hook it up to the guage or hook everything up dry and tight?
Thanks in advance.
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
#35245 09/18/2003 6:23 PM
Just dry and tight is fine. The pressure will be the same if it is air or oil, since there is no flow.
Paint & Body Shop moderator
#35246 09/18/2003 6:39 PM
If you want a quicker responding gauge, use 1/4" tubing instead of the 1/8" they come with. Last one I did like that I was able to tell when the engine was quart low by the needle flicker on braking or cornering. Surprises folks who've never seen an oil pressure gauge respond like that.
#35247 09/19/2003 12:34 AM
Z
Z Offline
i used a tee so i have both warning light and guage.i can't watch the guage all the time.
