| | | Forums66 Topics128,109 Posts1,056,262 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35244 09/18/2003 9:31 AM | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Chips oil pressure post got me thinking about hooking up an aftermarket guage to my 250. I know I replace the electric sender with the one for the guage. My question is... do you let oil into the line before you hook it up to the guage or hook everything up dry and tight? Thanks in advance.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
#35245 09/18/2003 6:23 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Just dry and tight is fine. The pressure will be the same if it is air or oil, since there is no flow.
#35246 09/18/2003 6:39 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | If you want a quicker responding gauge, use 1/4" tubing instead of the 1/8" they come with. Last one I did like that I was able to tell when the engine was quart low by the needle flicker on braking or cornering. Surprises folks who've never seen an oil pressure gauge respond like that. | | |
#35247 09/19/2003 12:34 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i used a tee so i have both warning light and guage.i can't watch the guage all the time. | | |
