2 members (BC59, Danielbolt), 210 guests, and 3 robots.
Topics128,149
Posts1,056,817
Members48,454
I want to convert my 46 3/4 ton front brakes to disc. All the packages I find are for 1/2 ton only. Is there a package available for the 3/4 ton? If not, will 1/2 ton spindles fit the 3/4 ton axle? I want to do this as cheaply as possible. Any help is appreciated.
Jerry Walker
Apprentice
Apprentice
I called ECI (www.ecihotrodbrakes.com) about this for my 41 3/4 ton
They told me to check my bearings for there part #'s
If the outer bearing ends with a 01 and inner bearing with a 52
There disc brake kit will fit.
It's a complete kit, mounts, caliper,rotor,hub,bearings, Only drawback is it's 5 lug!
Thanks for the help.
Jerry Walker
I believe the '41 3/4 ton and '46 3/4 ton are different. The 41's front spindle & king pin is the same as the '41 1/2 ton it's the axle and springs that are different. The '46 spindle is larger. To be sure you need to "mike" your spindle or check the bearing #'s.
Harold Wilson
41 Chevy 3/4 Ton
