| | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35183 11/19/2003 10:39 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Friend has a newly rebuilt 228 engine. Vac advance was not working, wo he pulled the dist and fitted a new vac advance. Its not 180 out of time. New points set at .016. The distributor that came with the engine is a 1112360. The book sais it should have a 1112390 however I do not know the difference. Here is the problem. With the vac hooked up the only way to stop engine knock is to retard the octane selector 3 clicks or 6 degrees??? Whats going on here? The initial advance is set nuts on the mark on the flywheel. However when adding in 2-3 clicks advance on the octane selector it starts to knock. Again the only way to get it to stop is to dial in 3 click or 6 degrees retarded? This has got me stumped? Could this be too strong a vac advance, we may have to limit the vac advance arm movement? Maybe it the wrong vac advance? Any and all ideas welcome.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#35184 11/19/2003 11:22 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Do you have the advance hooked up to ported vacuum?
#35185 11/19/2003 11:53 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Yhep it screwed right on the side of the Carter W1 carb in the stock location.
#35186 11/20/2003 2:57 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Tim, I have a Delco Remy book that lists a bunch of distributor applications..
An 1112360 lists as fitting a 1950 and 51 GMC 228, 248, 270.
An 1112390 lists as fitting a 1953 228. An 1112391 fits the 248, 270 and 302 of the same year.
The 1112360 has a contact set listed as requiring a D100P or 1944374 and a condensor number D201 or 1900272.
The 1112390 calls for a different numbered contact set, D105P or 1944375 as well as a different condensor, D203 or 1928111.
The cap and rotor part #'s are different as well..
I am not a real student of ignition timing or octane selectors but perhaps you have the wrong set of points in your distributor ??
The D105P could have superceded the D100P and they are one in the same ? Or they could be different parts..
If you want a scan or a fax of these pages, drop me an E mail and let me know.
I am not sure if any of this helps but it's all I got, lol..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#35187 11/20/2003 1:25 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Bill, Thanks for the reply. We will bump your info up against what he has installed and go from there. Thanks again.
#35188 11/20/2003 2:10 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Tim, if the truck runs well down the road, then it should be allright no matter what the timing say. There are minor difference in the advance curves with the different distributer #'s, but by the later on GM carried only the 1112403 distributer as a replacement,even for early models.The D105P or 1944375 is the point set used with the taller cap distributers. | | |
#35189 11/20/2003 5:33 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Thanks Tony, We can get it to run down the road under load without it pinging but only if the octane selector in the retard setting as described. Where we have the timing set starts it good and the vac is 21. It just didn't make sense.
Tim
#35190 11/23/2003 4:18 AM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Problem solved by drilling out the new vac advance arm and pinning to limit the travel. Some trial and error determined travel. Octane selector set at 2 clicks or 4 degrees now and initial timing on flywheel somewhat retarded.
