4 members (Nick in Manitou, TUTS 59, Alaska54, Cosmo), 54 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#35108 01/08/2003 12:42 AM
I know some of you have used hirsch high temp engine paint (Rugo?) and was wondering how it worked for you...I just did mine this past weekend and am unhappy with the results.
So...did you spray or brush on the paint, any thinning, priming, etc.
I sprayed mine and had to thin as suggested to get it to spray right, but it didn't cover too well, is puddled and heavy in some places and thin in others; color doesn't look right.
Your help is appreciated. Thanks...Tom
#35109 01/09/2003 12:06 AM
I used Hirsch Engine Paint and was not happy with the results. The spraying process went fine, it laid out smoothly. The trouble came after a few months of driving when the color changed from the original red to a pinkish purple color,.
I have since pulled the engine, rebuilt it, and re-painted it. I did not use Hirsch Paint the second time nor would I use it again..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#35110 01/09/2003 6:43 AM
Tom:
I am very sorry that your results aren't what you wanted. I just used the Bill Hirsch high heat rattle cans. There was no thinning at all. Just lots of prep to make sure there was absolutely no grease, dirt or oil on the surface to be painted. I am sure that you prepped everything as well. As for the long term of the paint, I am only taking the word of a couple of professional restorers. I have yet to put my painted engine back in my pickup yet. Perhaps I was very lucky to get the results that I did. I hope that the next paint that you put on your engine goes better than this time. Good luck with your restoration.
Rugo
53 3100
Smokem if you gottem, if you haven't gottem, I know where you can gettem.
Steve Rugg
53 3100
#35111 01/09/2003 3:24 PM
I have had good results from the Hirsch engine paints. Just brushed it on and it flowed out to a nice finish wih no brush marks. I found the guys there very helpful. They sent me several test strips to choose the right color from. I had no such problems with color change as mentioned by 53 4 me.
#35112 01/10/2003 4:18 AM
I guess I'll try brushing it on next time with a foam applicator brush, or use their own aerosol cans. I'm not concerned about the finish on the cast iron, just on the tin parts, like the valve covers and oil pan.
The engine is fresh from the engine shop, and I sprayed it down with a grease remover. I'll also try a mild paint stripper to remove the puddles and runs...use a bristle brush for better coverage on the cast iron. Thanks for your help.
