0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | Does anyone know the specifications of the 6 volt heater motors used in the air-flow heaters? Amp draw, RPM, ect.. | | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | Ok maybe nobody knows the answer to this question. Can somebody tell me what size fuse is used on the heater switch for a 6v system. It is the paddle type of switch not a rheostat. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hi ya Jim, I just went out an pulled mine for ya buddy! SFE-14 Thats for a stock 1950 deluxe heater, two speed fan, fuse off the back of the paddle switch. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | | dgiorgi Unregistered | | dgiorgi Unregistered | Hi Jim, according to my "official guide to 12 volt conversations" it states the 6 volt typical heater motor requires 10 amps, hope this helps. | | |
