Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Woogeroo, Tronman, Youngin' Tut 59, WarEagle1, PullG), 152 guests, and 3 robots.
Topics128,288
Posts1,058,579
Members48,492
#348358 12/13/2007 7:23 PM
steering stabilyzer for a straight axle '53 Chev 1/2 ton?
I've seen these mentioned on the boards before but don't see them advertised by the usual suppliers.
Do these just bolt between the axle and the tie rod???
You might check with the flaps, if you have one that carries Moog, for Moog part # SSD12. Same stabilizer shown in Tim's post, but you might be able to get it cheaper.
Bill Burmeister
Thanks guys!!
