| | | Forums66 Topics128,022 Posts1,055,376 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34733 05/23/2002 6:35 PM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | Well, today was the day. Fired up the engine for the first time since the rebuild. Awesome sound!!!! Haven't driven it yet but intend to tonight assuming we can get the generator working. It's not charging.
'54 3100 235 original engine Bored .060 over New pistons/rings Rod Bearings Turned crank Main bearings Mild cam lifters valves and seats oil pump Fenton headers Offenhauser intake Dual 2bbl. Holley/Webers Carb. and intake hot water heat Electronic ignition Fuel pump Beehive filter
Seek results, not perfection. Remember this is a truck, not a Rolex watch.
#34734 05/23/2002 6:43 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Great news Geoff ! Forget the generator, take it out before dark,, you won't need to turn on the lights..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#34735 05/23/2002 8:38 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Did you polarize the generator? If its been setting for long, it loses the field polarity.
Fred 52 3600 69 C-10
#34736 05/24/2002 2:40 PM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | Thanks for the suggestions guys. Ultimately we took the generator out and put in an alternator, so I din't get to drive it last night. I'll be driving it this afternoon if all goes well.
Funny things, these old trucks. Fuel pump worked when I drove it into the garage. Now all of a sudden it doesn't. So we replaced that.
Then the thermostat which worked upon initial start up yesterday, quit working suddenly in the afternoon. So we replaced that.
Then the generator. I bought this truck last spring with an alternator but I wanted a generator because I think they look better. So I took the generator and voltage regulator out of my old '54 which was working fine at the time, and now all of a sudden we can't get continuity through it -- or something like that anyway. So we put the alternator back, and I will send the generator out to have it rebuilt.
Seems like parts wear out by just sitting around.
#34737 05/24/2002 4:43 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | You cannot do as much with a Rolex watch!!! . . Just remember, if you were top sit around for a long time, you would have parts that wouldn`t work anymore either!
