5 members (Shaffer's1950, 5Window53, frogfarmer, TUTS 59, 1 invisible), 75 guests, and 1 robot.
Topics128,213
Posts1,057,488
Members48,473
I have a 87 Chevy S-10 frame. I want to put a turbo 350 transmission in this frame. I am looking for a supplier for a cross member to adapt the S-10 frame to that transmission. This is all going under a 46 Chev pickup.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
You don't need a supplier, just a piece of channel/tubing/angle to bolt to two angle brackets welded to the inside of the frame rails. Bolt the cross piece to the angle brackets so it is removable in case the trans has to be removed and drill holes in the center in line with the 350 mount cushion. A one hour job if your slow.
Here is a photo showing the left side of the fabricated member, it's in a 52 but the cab is so far above the frame on an S10 conversion it should apply to all years. For the AD guys it also shows how to hook the emergency brake cable to the factory E-brake rod. http://s32.photobucket.com/albums/d41/coilover/
Scroll down to first picture.
Evan
I believe Jegs has them. They sell the whole V8 conversion kit for S-10s, and I believe that's where I got the cross member from. It's about $70 or so. There is welding required, though.
~Jenny
"Custom can't be bought. It's achieved one cut at a time."
1950 Chevrolet 3100 1/2-Ton
Golden State Pickup Parts has one in their catalog.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
