| | | Forums66 Topics128,019 Posts1,055,343 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34506 11/14/2003 11:36 PM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | I'm looking at replacing all my brake lines(hard lines) and was wondering if anybody out there has any tips. Also what size is the tubing and how many feet do I need. 1950 1/2 ton :confused:
1950 1/2 ton 3 window
#34507 11/15/2003 12:06 AM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | My 50 took all 1/4" lines. It took a full roll(I think it was 25') and 1 other 5' piece.Also took 14 fittings. | | |
#34508 11/15/2003 12:23 AM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | how long did it take you?? was it a hard job?? thanx again.
#34509 11/15/2003 1:01 AM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | If I remember right it took about a day. Nothing hard about it, just a little tedious. Pull an old line and measure it with a string. Add about a 1/2" to allow for the flares. Cut a piece of new line to length. Flare one end and slip on a fitting. Bend it with a tubing bender to match the old line. Then flare the other end. Don't forget to slip on the fitting on the end before you flare it. | | |
#34510 11/15/2003 1:43 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I will second Ralphy on the "don't buy the cheapy flare kit", it is absolute garbage. The cheap jigs don't hold the tube secure enough and it slips through as you are attemting to make the flare. The cheapys use a wing nut to apply the pressure and the good ones use a heavy duty hex end. | | |
#34511 11/15/2003 1:52 AM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | As Ralphy says, good tools are a must. I picked up a Lisle brand flare tool at the parts store for about $40.00. Worked fine. Make sure the tubing end is square and burr free after you cut it. I used a file to clean up the end after cutting and also to put a slight taper on the tubing end before flaring. Also a drop of brake fluid on the die helps.
You will make a few mistakes, just take it in stride.
The 51's went to 3/16" lines. My 50 was all 1/4" and my 51 3/16". | | |
#34512 11/15/2003 4:18 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | What type of metal have we been talking about regarding the tubing. Steel or Stainless Steel. Is SS considerably more difficult to work with?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#34513 11/15/2003 5:11 PM | Joined: Sep 2003 Posts: 10 New Guy | | New Guy Joined: Sep 2003 Posts: 10 | I got a set of stainless steel brake lines from Inline Tube for about $175. When I got them three years ago, the project was a '75 Chvy 3/4 ton 2wd, but times, fortune and prjects changed and I just hung them on a my '83 one-ton 4wd chassis. I had to rebend the ends that connect for the front hoses and was able to do it by hand except for one end that required a tool. I wrapped the tubing in six layers of masking tape and used a pair of pliers. The tape prevented tube damage. In my inexperienced opinion, the SS is easier to bend than the steel lines, because they didn't seen to go flat in the bends so easily.
Quinn | | |
#34514 11/15/2003 5:43 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Consider installing a dual reservoir master cylinder while you're at it if you still have the old single. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#34515 11/15/2003 7:39 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I paid less than $100 for a dual master conversion kit, which included a bracket and linkage.
Since I was converting to disk brakes on the front at the same time, I was able to get an inexpensive rebuilt master that was less than $50, which seemed cheap, but a year later it still works fine.
I bought a 25' roll of tubing when I did mine, and I ended up buying a stick or two separately, but I think it was because I needed fittings I could only find locally that way.
My disks, master cylinder and rear brakes are all '73 Chevelle, so some of the specifics of my install might not apply to anyone elses.
When I converted to disks I discovered the original master had a 10 lb residual valve, and one I applied the brakes the disks would not release until I undid the brake line.... That's why I went dual master.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#34516 11/16/2003 7:15 AM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | Thanks for all your help. By the way I'll be using steel tubing.
#34517 11/17/2003 6:58 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | My tips, some have already been covered: -Summit sells 25' rolls...3/16, 1/4, 5/16, 3/8, less than a buck per foot. The sell misc tubing nuts...about $7 per bag (there's about 12 nuts per bag). Definitely the cost effective way to go. -I cut my tubing with a regular tubing cutter. -I use a Rimac flaring tool. Needs to be clamped in my vice to keep the tube from sliding, works great when clamped properly. -much harder to bend 3/8 tubing without kinking compared to 3/16. -built a jig that works with my grinder to grind the tube end bevel necessary for the double flare. -use old tubing for pattern or take careful measurements for new tubing, or make pattern using thin gauge welding wire. | | |
