0 members (),
151
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Or doesn't like them. About a year ago I saw used ones on Ebay and asked the owner why he was selling them..he told me he didn't like them (don't recall exactly why)
I've been planning on doing the front axle drop on my 55 Chevy, 2nd series this winter but still wanted to ask for more opinions about the mono's.
Keith | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I fall into the "don't like 'em" crowd. Too stiff. I'm going to try a dropped axle and stock springs with 3 leaves removed. | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | 53..
Same here..Will be getting a 3" dropped axle for my 55, 3600. I doubt 3" will be a "wow" for me..so maybe I'll steal some leaves also.
If I can convince myself that a 4" drop will not open up a can of worms...i.e. components interfering with each other, I'd go that way..
Keith
| | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | I installed monos on the front of my daily together with lowering blocks on the rear. That was 4 years ago and I never looked back.
They are anything but stiff after thorough break in! One leaf only gets really bouncy and quality gas shocks are a must.
I drive city, freeway, dirt roads, sometimes with loads and never once bottomed out. They meet and far exceed original spring specs, which have 10 times higher failure rate. I would recommend them for a daily truck that gets good use.
| | | | | Joined: May 2007 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 35 | I sure get this question a lot about mono springs. I drop axles and people are asking me all the time what I think of them. I've never used them because I thought the original worked fine. I like the stock travel and clearance. I do all the drop in the axle. | | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | When I got my '50 (not the same, I know, but similar) the owner before me had taken a leaf out of the front springs. I liked the stance. Not too low so that it isn't practical to drive but a little lower in the front. After 40 or 40K the springs finally broke. I replaced them with a mono leaf spring and it maintained the ride height and improved the ride quality. We drive this truck. I probably have another 30K on these springs and I have been completely happy with them. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | does anyone know they you are not suppose to run a dropped axle and mono springs? | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Man I hope not. That is how my truck is setup. I can't imagine why you couldn't unless the axle was dropped so much you couldn't get the tie rod to run under the truck. If that was the case you could always drop the steering arms to get the tie rod to drop down lower.
All of this takes very careful planning so you can still steer the truck. | | | | | Joined: Nov 2007 Posts: 20 Apprentice | | Apprentice Joined: Nov 2007 Posts: 20 | I have a 55 truck and want to lower the stance. What is the least expensive way to do this. Like everyone, I'm on a tight budget. How do you remove the leaf's out of a spring and how do you know how many to remove wittout effecting the safety. Is it safe for lowering blocks on the rear end? | | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | I love the monoleafs - both the look and the ride. They drop the front end about four inches and you don't have to change a thing - suspension, steering or anything else. I do have gas shocks, but that's the only change other than the monoleafs. I dropped the back end four inches to match. The rear springs are stock, but I put gas shocks on that too. Here's a before picture and here's an after picture. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Looking good Eagle!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
