1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34179 07/14/2004 2:46 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | I've got a guy looking at my 3/4t frame.1950 He has a 50 1/2 ton with a broken and rusted thru frame. I know the 3/4 is longer, but the cab and sheet metal will all bolt up. I'm going to take a tape the the front and rear axel tonight, but he is wondering if they are the same width. I believe that you could bolt a 1/2t front axel to a 3/4 t frame, but I want to make sure. Anybody know?????????? | | |
#34181 07/14/2004 4:12 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The steel is thicker and the frame is longer. We used to have a guy here who used the 3/4 ton from to build 1/2 tons for his customers. He felt the added strength was worth the work.
Fred 52 3600 69 C-10
