8 members (kurbside bolter, tclederman, FAST55, Hotrod Lincoln, KEVINSKI, 1955 1 Series, Charles in CA, Otto Skorzeny), 153 guests, and 2 robots.
Topics128,267
Posts1,058,373
Members48,485
Page 2 of 2 1 2
I have two comments:
1) Easy-outs that break off are not easy-outs, they become a whole lot of grief!
2) With the welding rod idea, what stops the bolt itself form welding to the block threads ?
1951 1 Ton Completed
I have read everyones posts and one things stands out as an un-answered question. Yes you broke 2 bolts and you have several options on getting them out but, why did they break! I don't know what size bolts hold the mains down in a 292 but I'll guess 7/16, these shouldn't have snaped at 100 foot pounds of torque period. The torque value on the main caps is based on main cap deformation not the max torque value of the fastener. Even if you did torque the bolts to 95 if they were healthy bolts they should have perhaps deformed the cap and tied up the crank but not break. The only way a bolt that size is giong to break at that value is if it bottomed out or was not up to par in the first place
Steve Lemberg
1936 Chevrolet 1 1/2 ton truck
1970 Mercedes 280SE 3.5 coupe
1987 Mercedes 560SEC supercharged
1989 Mercedes 300CE 5.0 M119
I was thinking the same thing Steve ,, perhaps they were not correct main brg bolts ,, just some replacement ones ??
The 216 - 235 main brg cap bolts are torqued to 100 / 110 ft lbs . May be bigger dia bolts though.
Page 2 of 2 1 2
